It is currently Mon Aug 04, 2025 10:02 pm
PostPosted: Thu Nov 01, 2018 4:58 pm
Just finish this guitar using some of the finest Brazilian Rosewood I’ve ever seen in my life.....
And I have had this set for about 20 years.
Adirondack spruce top, snakewood head veneer, backstrap, bridge pick guard and bindings and heel cap.
Spanish Cedar Neck with rosewood center stripe
Graph Tech Ratio tuners-I am very pleased with these if you’re not familiar with them you should look them up they really are interesting And work extremely precisely.
Nitro finish
Ivory nut and saddle
These users thanked the author Brad Goodman for the post: bcombs510 (Thu Nov 01, 2018 5:08 pm)
PostPosted: Thu Nov 01, 2018 5:08 pm
First name: Brad
Last Name: Combs
The Brazilian is goodness. :)
What do you put the wood pickguard down with? I’m guessing it’s not finished in place, right?
PostPosted: Thu Nov 01, 2018 5:16 pm
It is sanded and buffed( waxed) before I put it on the guitar with the special double stick tape.
These users thanked the author Brad Goodman for the post: bcombs510 (Thu Nov 01, 2018 5:45 pm)
PostPosted: Thu Nov 01, 2018 5:48 pm
City: Tyler
Ooohh!
PostPosted: Thu Nov 01, 2018 6:30 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
The snakewood looks great against the BRW. And the BRW is among the nicest I have seen.
Ed
PostPosted: Thu Nov 01, 2018 7:28 pm
Last Name: Sollod
Very Nice! [:Y:]
www.swiftcreekguitars.com
PostPosted: Thu Nov 01, 2018 7:54 pm
Pretty nice BRW...
LiIke the tuners, must be high gear ratio. Buttons come off?
PostPosted: Thu Nov 01, 2018 8:54 pm
Haans wrote:
Pretty nice BRW...
They are actually all different ratios depending on the core thickness of the string-from 39 to 1 to 12 to 1
The theory being that you turn the it the same amount no mater which string.
And no the buttons don't come off....
These users thanked the author Brad Goodman for the post: Pmaj7 (Fri Nov 02, 2018 8:37 pm)
PostPosted: Thu Nov 01, 2018 9:45 pm
First name: Larry
Last Name: Hawes
SWEET!
Thank You and Best To All
PostPosted: Thu Nov 01, 2018 10:06 pm
That is a beaut! Congratulations. Pretty hard to go wrong with Adi and BZ on anything. Everything I have built with that combo has been hard to let go. Are you going to be able to? :)
Do you do your own finishes? Hide glue? Why Snakewood for the bridge? Have you had a good experience using it for that and how do you think it compares to BZ or Ebony.
One question. Whenever I join a back I usually check the strength of the joint on the off cut and see where it breaks. Whenever I inlaid a centerstrip with purfling on either side it always broke along one of the purfling lines. That has led me to just inlay a strip of plain wood, either contrasting or the same as the back. That seemed a lot stronger. Has anyone ever seen a back crack along a centerstrip purfling line? Maybe it is an unnecessary worry.
Well done!
PostPosted: Fri Nov 02, 2018 5:41 am
Nice one Brad.
PostPosted: Fri Nov 02, 2018 8:14 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That is beautiful!
Bryan Bear PMoMC
PostPosted: Fri Nov 02, 2018 9:02 am
Well done!
Yes, I do my own finishes. I have been trying to do the nitro as thin as possible.
This is the first time I have used Snakewood for a bridge- I chose it for aesthetic reasons. It is similar in density to ebony.
I have used hide glue on and off for several years, but am back to using Titebond ... A lot of my work sessions are only an hour so that complicates using hide glue.
I haven't had any problems with the center seams with purflings in them. I do use a back reinforcement.
These users thanked the author Brad Goodman for the post: Terence Kennedy (Fri Nov 02, 2018 12:54 pm)
PostPosted: Fri Nov 02, 2018 9:17 am
Very nice! Good work
PostPosted: Fri Nov 02, 2018 12:53 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
More great inspiration!
PostPosted: Fri Nov 02, 2018 3:45 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Nice looking guitar and bet it sounds great.
Interesting tuners that I have never heard of before. Would you choose to use them again?
PostPosted: Fri Nov 02, 2018 4:57 pm
First name: D
Last Name: S
Oh man, that looks great!
The tuning keys are dope!
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Nov 02, 2018 8:12 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
Very, very nice Brazilian RW. You do not see that grain quality very often, even with well-quartered instrument grade Brazilian RW -- that set is special !!!
PostPosted: Fri Nov 02, 2018 9:05 pm
Yes, it is really sounding great-starting to open up.
I am planning on using these tuners again. Aside from the whole different ratio concept (which I like) they are extremely smooth and tight.
I also like the way they look. They also make more traditional looking closed back models with solid buttons.
PostPosted: Sat Nov 03, 2018 1:15 pm
Pretty guitar. Peghead appears to have an oriental theme. Interesting tuner design. The "wrap around" worm gear surface looks like a good way to make a stronger unit.
PostPosted: Sat Nov 03, 2018 6:24 pm
[quote="Clay S."]Pretty guitar. Peghead appears to have an oriental theme. Interesting tuner design. The "wrap around" worm gear surface looks like a good way to make a stronger unit.[/quote
I designed that head shape 45 years ago when I was 14 years old-just made it up out of my imagination. the funny thing is I have seen almost identical designs in Queen Anne furniture...
PostPosted: Sat Nov 03, 2018 7:55 pm
"I have seen almost identical designs in Queen Anne furniture..."
The Queen Anne style became popular during the same period that tea drinking became popular in England and had some oriental influences as did the preceding William and Mary style of furniture. An unusual but elegant peghead.
